OpenID Connect in SystemLink Is Not Available
Updated Jul 20, 2023
  • SystemLink
I am trying to enable OpenID Connect in SystemLink by following the SystemLink Operation Handbook , but after completing the steps I do not see the options in the Role Mapping dropdown.
The OpenID Connect feature in SystemLink requires a SystemLink Server Advanced license, if you are using a SystemLink License Server Standard license you will not be able to access that feature. The recommendation is to upgrade to an Advanced license if you are using a Standard license and would like to use the OpenID Connect functionalities.
The license requirements for the OpenID Connect and other features are detailed in the Purchasing SystemLink Licenses section of the SystemLink Manual.
