What's the definition of Maximum Offset Bandwidth in 5842 specification?
Updated Jul 4, 2023
  • PXIe-5842
  • NI-RFSG
  • NI-RFSA
I'm reading the RF specification of PXIe-5842. In Table 4, I'm not sure what's the definition of Maximum Offset Bandwidth; do we have any document elaborating on this part?
PXIe-5842 could operate on Zero-IF (Full BW), Low IF mode (high dynamic range), or Direct Sampling mode depending on the frequency range and the signal bandwidth selected for the input/output signal:
Zero IF means the LO is tuned at the center of the signals which can give us the full bandwidth; on the other hand, the Low IF mode in contrast is off-tuning the LO outside of the signal, which means we cut off the bandwidth on one side.
The benefit of Zerof-IF mode is that we could have the full bandwidth on the spectrum, while Low IF mode could provide us with a better dynamic range and reduce the potential residual LO leakage power.
If you want to learn more about these two concepts, please refer to this VST3 Introduction document .
In LabVIEW property node they're either NI-RFSA Downconverter Frequency Offset Mode property or NI-RFSG Upconverter Frequency Offset Mode property (Table 2 ). You could see such property in either LabVIEW or RFmx SFP.
