Error 500 and 503 in SystemLink Web Interface
Updated Jun 27, 2025
  • SystemLink Server
  • When accessing my SystemLink server in a browser, I see errors 500 and 503. What causes this?
  • When I launch the SystemLink web interface, I see one of the following errors. How can I resolve this?
The dashboard could not be opened. The request to get the dashboard failed with error code 503.
The request for tags failed with error code 500.
The request for alarm instances failed with error code 500.
Errors 500 and 503 can be caused by improper installation, firewall and security settings, incorrect network settings, insufficient memory, or insufficient server specifications. Follow the steps below to fix these errors:
  • If this error appears when attempting to access the server's URL from a client system, check whether the SystemsManagement service is running on the server.
    • This can be checked from the NI SystemLink Service Manager tab of the NI SystemLink Server Configuration application.
    • If this service has stopped running, verify that the client has the correct DNS configuration (i.e. that the computer name matches the IP address). If there is a DNS problem, it will be necessary to:
      • Delete the client system from SystemLink.
      • Flush the DNS.
      • Stop and restart the net logon.
      • Reconnect the client in SystemLink.
  • If several SystemLink modules have been installed, remove any that are not actively used.
  • Ensure that your server PC meets the minimum specification requirements.
    • View the requirements in the Readme document. The Readme for each SystemLink version is found on the download page.
    • Note: If using the SystemLink TDM DataFinder module, NI strongly recommends having more RAM, Disk space and CPU cores than the specified minimum. This is because the TDM DataFinder Module requires the use of databases, which will grow in size depending on your use case.
  • Verify that all SystemLink services are running.
    • In the Windows Services application, all services starting with "NI SystemLink" should be set to Running and Automatic.
    • In the SystemLink Server Configuration application, all services should be running under the NI SystemLink Service Manager tab. If any are not running, try restarting them and following any troubleshooting prompts in the Troubleshooting tab.
  • If using a firewall, follow Network Ports Required for SystemLink  to ensure that all necessary firewall ports are open.
  • If using any Group Policies or anti-virus software, work with your IT department to disable these features and try again.
