Do I Need to Calibrate a CompactRIO Controller?
Updated Oct 10, 2023
  • cRIO-9002
I have received a cRIO controller and would like to know if it is necessary to calibrate it or periodic maintenance.
cRIO controllers do not need to be calibrated, and the only aspect to consider is the CMOS Battery because this is not user-replaceable. See the details here.
On the other hand, the C Series modules are suggested to be calibrated following the procedures listed here.
