Can the USB 3.1 Alt DisplayPort on the NI sbRIO (i.e sbRIO-9629) be used to connect to a USB-C-based display adapter available in the market? I am specifically planning to use a “USB-C to Dual HDMI Adapter” to display two different images on separate screens.
NI has only tested the display adapters listed below with sbRIO-9609, sbRIO-9628, and sbRIO-9629. For any other adapters, NI cannot warrant that they will work, and testing will be required.
