The commands supported by the SystemLink Data Preprocessor instance's job file are not similar to those supported by the job file of DataFinder. The table below describes the commands supported:
Command | Description | Parameter | Parameter Values |
ProcessFile | Processes a file | Reprocess |
- True - Data Preprocessor instances always reprocess the file.
- False - Data Preprocessor instances process the file only if the file has changed or has been added since the last processing. (default)
ProcessFolder | Processes a folder | Reprocess |
- True - Data Preprocessor instances always reprocess the folder.
- False - Data Preprocessor instances process the folder only if files in this folder have changed or have been added since the last processing (default).
ProcessFolder | Processes a folder | IncludeSubfolder |
- True - Data Preprocessor instances also process subfolders (default).
- False - Data Preprocessor instances do not process subfolders.
