Printing LabVIEW Front Panel Without Using Additional Toolkits and Libraries
Updated Jun 1, 2025
I would like to print LabVIEW VI front panel by using LabVIEW without any additional toolkits and libraries.
In LabVIEW, there is a possibility to print the front panel without using any additional toolkits and libraries.
In order to print LabVIEW front panel please follow the steps described below:
  1. First of all, we need to create a new VI, which should use the mentioned code.
  2. In Select VI/File control select a VI path that you would like to print.
  3. Run the VI and wait until the printing of the VI.
Note: If in the Windows setting the default printer is selected as a "Microsoft Print to PDF" after running a VI you will
          receive a pop-up window to select a path for saving a report in PDF format.
