Unexpected Behavior of DAQmxCreateCOPulseChanTicks initialDelay Parameter In NI-DAQmx C API
Updated Aug 19, 2026
Programming Language
  • C
I want to delay the pulse generation for N amount of master clock pulses, the "DAQmxCreateCOPulseChanTicks" seems to have that exact parameter. When experimenting with various values, the delay is always the same, it always waits 4 ticks after generating the first pulse. What is the reason for this behavior?
The reason for such behavior is that TIO (Time-Interval Output) only applies the initial delay on the very first trigger of a retriggerable task. As a result, if the delay is not being changed on the retriggers that is expected, however if you cannot see the trigger on the first trigger event, then that is unexpected, and you should contact NI Support
In the X series devices, a new attribute "CO.EnableInitalDelayOnRetrigger" has been added, that will apply the initial delay to all retrigger events.
