I use a NI-XNET compatible module with cRIO-906x.
- Running the CAN examples for NI-XNET devices results in an error -52018.
- When I run the NI-XNET application, I get the following error:
Error -52018 occurred at XNET Write (Signal Single-point).vi
Possible reason(s):
A hardware failure has occurred. The operation could not be completed as specified.
When CAN communication is enabled via the NI-XNET modules, the system intermittently throws the following errors in the Distributed System Manager:
-65512 (The data transfer for some I/O variables on this target could not be completed in the allotted time, and the updates for some values may have been delayed. Increase the Scan Period to avoid this problem.)
-66460 (The I/O scan time exceeded the NI Scan Engine period you specified on the Scan Engine page of the target properties dialog box.)
-66461 (The I/O scan was repeatedly late, and the NI Scan Engine terminated to ensure controller stability. Correct the source of lateness and clear all major faults to restart the scan engine.
