To use the AIM MIL-STD-1553 VIs on LabVIEW you must add the library through JKI VI Package Manager. Follow the next steps:
1. Confirm that the installation was successful. The installation will result in the creation of a Start Menu entry which can be located by going to
Start » All Apps » AIM GbmH » MIL-STD-1553.
2. Open the JKI VI Package Manager and select
Open Package File(s).
3. This action will open a new window. Search the
\Add-Ons\LabView folder usually located at:
C:\Program Files\AIM GmbH\MIL-STD-1553 Windows BSP 14.1.2\Add-Ons\LabView4. Select and add the .VIP file inside the folder.
5. Select Add to Library & Install.
6. Select Finish.
