LO Setting Could Not Be Locked When Used RFmx Limited Configuration Change
Updated Jun 6, 2023
  • RFmx
You found LO source setting is not locked sometimes when you use RFmx signal name with Limited Configuration Change. You tried to share LO(LO_In) using RFmx signal name and Limited Configuration Change, but it isn't set to LO_In when they call 'initiate' with the signal name. Why did it not work ?
Refer the feature specification document , there is some problems with RFmx debug mode. Check the code , disable the debug mode , the LO setting can be locked with LCC.
