Error -5580899 in LabVIEW Using VI Connect (PuTTY).vi
Updated Jan 19, 2026
I'm trying to connect to a remote system using the SFPT VIs (the PuTTY one) but I keep getting this error:
Error -5580899 occurred at NI_SFTP.lvlib:Low Level Connection.lvclass:Interact with Subprocess.vi:3570001
Is there something else I should do?
This error is usually triggered when PuTTY, the SSH and Telnet client, is not installed on the host computer.
Once PuTTY has been successfully installed and verified, restart the LabVIEW application. This ensures that LabVIEW recognizes the newly installed PuTTY components and incorporates them into the system's environment and with PuTTY installed and properly configured, the VI Connect (PuTTY).vi module should execute successfully without any further issues.
Ensure that the user account running LabVIEW has sufficient permissions to access and execute PuTTY. Administrative privileges may be required in some cases, especially during the installation of PuTTY or system environment configuration.
If PuTTY is already installed and the issue persists, try repairing LabVIEW from NI Package Manager. This process removes potential file corruption and helps LabVIEW recognize the installation correctly.
