When using a DIAdem version earlier than 2020 with an Ethernet CompactDAQ (cDAQ) device, analog signal measurements in DAC using NI-DAQmx driver input do not work, an error is thrown:
Error in Start
Error No.:-52005
: NIDAQmx returns the following error:
The parameter received by the function is not valid.
The error is shown in the following dialog box.
The NI I/O Trace for NI-DAQmx shows the errors -52005 and -201401.
