Error -52005, Analog Data Acquisition With Ethernet cDAQ Fails in DIAdem
Updated Mar 6, 2025
  • cDAQ-9181
  • cDAQ-9183
  • cDAQ-9185
  • cDAQ-9184
  • cDAQ-9187
  • cDAQ-9188
  • cDAQ-9189
  • DIAdem
When using a DIAdem version earlier than 2020 with an Ethernet CompactDAQ (cDAQ) device, analog signal measurements in DAC using NI-DAQmx driver input do not work, an error is thrown:
Error in Start
Error No.:-52005
: NIDAQmx returns the following error:
The parameter received by the function is not valid.
The error is shown in the following dialog box.
The NI I/O Trace for NI-DAQmx shows the errors -52005 and -201401.
The error is due to a bug, which is fixed in DIAdem 2020.
Please upgrade DIAdem to 2020 or a later version, as there is currently no known workaround for this issue.
