Get All File Property Names Using Swagger UI in SystemLink
Updated May 31, 2023
  • SystemLink
I am using the Swagger UI command POST /ods/{conI}/ni/data-read to get the property name of my file. However, when I receive the response, I only receive the property underlined in the red box below, the others are missing. How can I retrieve all my file property names?
To solve the issue those properties that do not appear on the Swagger UI result query should be retrievable after they have been optimized. This can be done in Data Indexing for that specific DataFinder, under Custom Properties tab select those properties and click optimize.
