Error -1074384882 Occurred When Using NI-XNET Bus Monitor
Updated May 31, 2023
  • PXI-8517
  • NI-XNET
I am using a PXI-8517 to do a loop test in VeriStand. I want to monitor the FlexRay traffic through NI-XNET Bus Monitor at the same time. As both FlexRay ports are occupied by VeriStand, I set the Run Mode to Subordinate. But I still get the following error:
Unfortunately, XNET doesn't support opening two Stream Sessions with FlexRay at the same time. This ability is added with CAN and LIN, but not with FlexRay. The only way to monitor the traffic with FlexRay in NI-XNET Bus Monitor is by using another FlexRay port.
