Network Ports Required for SystemLink™
Updated Jun 19, 2026
  • SystemLink
  • I am having trouble connecting clients to my SystemLink Server. What network ports does SystemLink™ need to communicate?
  • What ports should I whitelist or open in my firewall for SystemLink™ to work?
SystemLink™ requires the following network ports to be open on the server:
  • Port 80 (for insecure HTTP)
  • Port 443 (for HTTPS)
  • Ports 4505-4506 (for Salt Service)
  • Port 5672 (for RabbitMQ — required to support legacy client communications; disabled by default)
  • Ports 2343, 2809 and 59110-59210 (required for SystemLink™ TDM modules' functionality only)
  • Ports 59100-59110 (for LogosXT — required for OPC UA connectivity only)
The SystemLink™ installation process manages port configuration, so generally, no additional steps are required. However, some anti-virus or IT security software can block the opening of these ports. SystemLink™ does not open ports on the client device(s).
Refer to Network Security - SystemLink Operations Handbook for a detailed description of the protocols used by SystemLink Server.
