No Value Shown When Open XNET Frame TDMS in DIAdem
Updated May 24, 2023
  • LIN Interface Device
  • CAN Interface Device
  • FlexRay Interface Device
  • DIAdem
  • NI-XNET
I using CAN Input Stream to TDMS Logfile.vi LabVIEW example receiving all CAN frames and store the frames as TDMS file format. When I open TDMS in DIAdem, it don't shown any value in VIEW tab and don't pop out any error or warning. I tried checked DIAdem DataPlugin setting and it shown support TDMS file format.
How should I solve this issue?
You will need to use DIAdem Bus Log Converter to convert logfiles from CAN, LIN, and FlexRay buses into the TDM data format
Then, you can open the converted TDM file in DIAdem and it will shown the frame value stored.
