Can I Disable the Poe Function on My PXI Frame Grabber Module
Updated Oct 22, 2026
  • PXIe-8246
  • Frame Grabber Device
I would like to disable the Power over Ethernet (PoE) function on my PXI Frame Grabber Module because I want to power my PoE camera through a different connection.
When I connect a PoE-capable camera to the RJ-45 port of the PXI Frame Grabber Module, I need to prevent the module from supplying power to the camera.
NI does not provide an option to disable the PoE function on PXI Frame Grabber Modules.
When a PoE-capable camera is connected to the RJ-45 port of the PXI Frame Grabber Module, the module automatically:
  1. Detects whether the connected camera supports PoE.
  2. Enables PoE if a PoE-capable camera is detected.
This detection and enablement process is performed automatically by the hardware.
Additional considerations:
  • PoE status information is not communicated to the host system.
  • No supported software setting or configuration option is available to disable PoE functionality on supported PXI Frame Grabber Modules.
PoE detection is handled internally by the PXI Frame Grabber Module and does not expose a user-configurable setting to enable or disable power delivery.
