For a shipping example from the System Configuration Driver that will list the connected hardware to the machine, assuming a computer with version of LabVIEW 2021 64 bits, then the folder path will be /usr/local/natinst/LabVIEW-2021-64/examples/nisyscfg. Once the example to run is determined, to execute use the command labview64 Show\ All\ Hardware.vi
In this case, the escape character is used ("\") between the words to prevent the shell to interpret those as separate arguments and not as a single file.
