Can I Run Multiple FPGA VIs Simultaneously on the Same FPGA Target?
Updated Sep 28, 2023
  • LabVIEW FPGA Module
Can I run multiple FPGA VIs simultaneously on the same FPGA target?
No, you can’t run more than one FPGA VI at the same time. The second FPGA VI will throw an error as shown below:
However, you can run more than one Open FPGA VI Reference (make sure that you have unticked the Run the FPGA VI option for each function). Then, you can run only one of these FPGA VIs at a given time, by using the Run and/or Abort invoke method.
