Peripherals Created With NI Single-Board RIO CLIP Generator Not Available
Updated Jun 9, 2023
  • sbRIO-9603
  • sbRIO-9607
  • sbRIO-9608
  • sbRIO-9609
  • sbRIO-9627
  • sbRIO-9628
  • sbRIO-9629
  • sbRIO-9651
Other
I'm trying to use the RS-232 serial 2 port on my CompactRIO Single-Board (sbRIO), I sat the serial 2 RX/TX lines in the CLIP file, but when I tried to pick the serial line, I can only pick Serial 1 and cannot find serial 2. Is there a step I'm missing in order to use these DIOs for serial 2?
Ethernet, CAN, RS-232, RS-485, and RMC processor peripherals created using the CLIP generator are all are routed through the FPGA. These peripherals will be temporarily unavailable when the FPGA is reconfigured. Downloading your FPGA application to the flash of the sbRIO ensures that the FPGA is configured before the driver can access a given peripheral.
Once you recompile the FPGA, you should be able to find your peripherals created.
