DIO are Not Runing at the PCL Rate
Updated May 16, 2023
  • VeriStand
Looping back a Digital Output to a Digital Input on a static digital board such as a PXIe-6509, I observe a latency that does not match the Primary Control Loop (PCL) rate.
The VeriStand Engine architecture dedicates a specific loop (Low priority) to DIO tasks that are running in parrallel of the PCL. To specify the DIO rate, you can change the setting the in main page of the system definition file as shown below:
Refer to VeriStand Engine - NI documentation for a better understanding of the data path between the PCL and DIO loop.
