What is the difference between Channel Estimation types and L-LTF Enabled in RFmx WLAN
Updated May 16, 2023
  • RFmx WLAN
When you used the channel estimation feature to improve the EVM performance in RFmx WLAN , you will see below setting panel:
Check the help document , you can find below information about the types, like below picture:
You can see the channel estimation also used the LTFs , why did NI add the L-LTF enabled feature ?
First , the LTFs is not including the L-LTF. The LTFs are meaning for EHT-LTF , HE-LTF , VHT-LTF,HT-LTF , so we can think the LTFs as x-LTF; The spec only defined the channel estimation using the "LTFs" , which are no including the L-LTF; To enable the L-LTF for channel estimation , you can get a good improvement on EVM , but it is out of specs.
For example, the frame structure show as below for 802.11be :
EHT-LTF and Data part are using for channel estimation in specs , the L-LTF can be used for channel estimation as one optional solution;
