USRP-295x Detect Unexpected Signals Without Connecting Input
Updated May 12, 2023
  • USRP-2955
I use USRP-2955 with sample program (Rx Streaming (Four Channels) (Host).vi). When I test Channel 1 (RF0/RX2) without connecting any signal, it detect following signal. Why?
This is not the signal and it happens due to wrong setting of the measurement. When you use "LO Configuration = Share", two channels sharing the LO should be enabled. If Channel 0 is not enabled while you share LO for Channel 1, the measurement cannot be performed and you cannot detect any signal.
For the correct measurement, you need to set LO configuration = Independent to use own LO for each channel. In this case you can still see some spurious but you can measure signals. For USRP-RIO, there is no specification about s
