What Is the Minimum Baud Rate for USB-8506
Updated Dec 11, 2023
  • USB-8506
I am going through the USB-8506 specification sheets and can only find the maximum baud rate of this hardware. What is the minimum baud rate for USB-8506?
USB-8506 is using the NXP TJA1028 LIN transceiver which supports baud rates up to 20 kbit/s.
The TJA1028 LIN transceiver specification can be seen here(External Link: LIN transceiver with integrated voltage regulator). From this transceiver specification sheet page 8, the baud rates from 2.4 kBd up to 20 kBd and is LIN 2.0/LIN 2.1/SAE J2602 compliant. Thus, the Min Baud Rate would be 2.4kBd.
