In 3GPP defined 5G NR, a single RF carrier bandwidth can be from 50MHz and up to 400MHz in frequency range 2. If the users test 5G NR transceiver and to check the RF signal analysis result of the transceiver with NI RFmx (Latest tested version 2023 Q2) and VST (PXIe-5831/5832), he/she will encounter error message Error: PLL could not phase-lock to the external reference clock. Make sure your reference clock is connected and that it is within the jitter and voltage specifications. Also, make sure the reference clock rate is correctly specified - Error code 1074097770.
This article discusses an alternate method for measuring RF transceiver with RF bandwidth of 200MHz. The intended audiences are NI-RFmx users who have basic knowledge of 3GPP 5G NR specifications, NI-VST and NI-RFmx.
