The cRIO-904x and cRIO-905x are both the latest generation of CompactRIO systems, but they have some key differences. Understanding these differences will help determine which system is better suited for your specific application.
FPGA Technology:
- cRIO-904x Series: Equipped with a Xilinx Kintex-7 FPGA, which offers higher logic cell count and more powerful processing capabilities. It is suitable for applications that demand advanced processing and complex control algorithms.
- cRIO-905x Series: Utilizes a Xilinx Artix-7 FPGA, known for its balance between cost-effectiveness and performance. It provides reliable real-time control and data acquisition capabilities, making it suitable for a wide range of industrial applications.
Logic Cell Count and Resources:
- cRIO-904x Series: Offers a higher logic cell count compared to the cRIO-905x series, providing more resources for implementing complex logic and digital signal processing algorithms.
- cRIO-905x Series: Although it has a lower logic cell count, the cRIO-905x series still provides sufficient resources for many control and data acquisition applications.
Performance:
- cRIO-904x Series: With its higher logic cell count and the use of the powerful Kintex-7 FPGA, the cRIO-904x series can handle more computationally intensive tasks and is better suited for applications requiring advanced processing capabilities.
- cRIO-905x Series: While it has a lower logic cell count, the cRIO-905x series provides reliable performance for a wide range of industrial applications and offers a balance of cost-effectiveness and performance.
Connectivity and I/O Options:
- Both series offer similar connectivity options, including Ethernet ports and USB ports, allowing for easy integration with external devices and networks. However, the 904x includes two serial ports (RS-485 and RS-232) and DisplayPort Alt Mode in one of their USB 3.1 port allowing the embedded UI feature while the 905x just includes device port with Console Out on its USB 2.0 port.
- Both series support the use of C Series modules, enabling expansion and customization based on specific application requirements.
To determine which system is better for your application, consider the following factors:
Application Requirements: Evaluate the specific requirements of your application, such as processing power, I/O requirements, and complexity of control algorithms. If your application demands advanced processing capabilities, the cRIO-904x series may be the better choice. However, if your application has more modest requirements and cost-effectiveness is a consideration, the cRIO-905x series might be suitable.
Cost Considerations: The cRIO-905x series, with its Artix-7 FPGA, offers a more cost-effective solution compared to the cRIO-904x series. If cost is a significant factor, the cRIO-905x series might be the preferred option.
Future Scalability: Consider the potential for future expansion and scalability of your application. Both series support the use of C Series modules, but if you anticipate the need for more advanced functionality and processing power in the future, the cRIO-904x series with its higher logic cell count may provide greater flexibility.
It is advisable to consult with our sales team, or authorized representatives to discuss your specific application requirements in detail. They can provide more personalized guidance based on your needs, ensuring you select the most appropriate CompactRIO system for your application.
