Performing a FlexRay Interface Loopback Test in VeriStand
Updated Sep 21, 2026
  • PXI-8517
  • FlexRay Interface Device
  • PXI FlexRay Interface Module
  • VeriStand
  • NI-XNET
This tutorial shows how to conduct a FlexRay interface device (such as PXI-8517) loopback test in VeriStand.
Before you begin, make sure you have the following:
To perform a loop-back test on your FlexRay interface device, follow these instructions:
1. Connect the 2 ports of your FlexRay device together by using an appropriate cable.
2. Create a blank VeriStand Project.
3. Set up the VeriStand project correctly to your target controller.
4. Add FlexRay port.
5. Add NI-XNET example database file.
6. Click and open FlexRay Port 1 >> Outgoing. Right-click Cyclic and select import frames.
7. Select FlexRayCyclicFrame1.
8. Click and open FlexRay Port 2 >> Incoming. Right-click Single-Point and select import frames.
9. Change ECU to FlexRayExampleECU2 and select FlexRayCyclicFrame1.
10. Click FlexRay Port 1. Enable Cold Start if a start-up frame is not added in the Outgoing and set Key Slot as a number that must be within the number of static slots in this cluster. If a start-up frame is added in the Outgoing, it is not necessary to enable Cold Start.
11. Click FlexRay Port 2. Enable Cold Start and set Key Slot as a number that must be within the number of static slots in this cluster.
12. Save and deploy the VeriStand project. You should be able to control FlexRay Port 2 reading value by changing the FlexRay Port 1 value.
