It is currently not possible to import data back to the data tab. If you want to include it in your project for easy access, you can add it back by:
- Select the Project Files tab.
- Right-click your FlexLogger project.
- Select Add file.
4. Browse to the location of your file, select it, and click Open.
Note that this will include your files in the Project Files section, but it would not be available in the Data tab.
