The following table lists the derated current values for the PCI-6514 and PCI-6515 devices at a 100% duty cycle.
| Ambient Temperature | PCI-6514, All Lines | PCI-6514, One Line per Port | PCI-6515, All Lines | PCI-6515, One Line per Port |
| Up to 25 °C | 75 mA | 350 mA | 125 mA | 475 mA |
| Up to 35 °C | 65 mA | 350 mA | 125 mA | 425 mA |
| Up to 45 °C | 55 mA | 350 mA | 115 mA | 375 mA |
| Up to 55 °C | 50 mA | 300 mA | 100 mA | 325 mA |
For the 6514 at a temperature of 25 °C, if you are using all 8 lines in a port at the same time, a maximum of
75mA can be output from each line . Hence, the port can have a total maximum current output of
600mA (75mA x 8 = 600mA). If all 8 lines are not being used, the port can still output 600mA, but no one line can output more than
350mA. One example would be having line 0 draw 350mA, and line 1 draw 250mA. This would meet the current requirements for both the lines (350mA or less) and the entire port (600mA or less).
The same conclusion can be drawn for each of the other 651x devices respectively. Please make sure to observe the different current specifications for different temperature ranges, as well as PCI vs PXI. Below are tables taken from the help file for the 6516, 6517, 6518, and 6519. Please see the NI 651x User Manual (linked below) for the full specifications.
The following table lists the derated current values for the PCI-6516 and PCI-6517 devices at a 100% duty cycle.
| Ambient Temperature | PCI-6516, All Lines | PCI-6516, One Line per Port | PCI-6517, All Lines | PCI-6517, One Line per Port |
| Up to 55 °C | 50 mA | 350 mA | 100mA | 325 mA |
The following table lists the derated current values for the PCI-6518 and PCI-6519 devices at a 100% duty cycle.
| Ambient Temperature | PCI-6518, All Lines | PCI-6518, One Line per Port | PCI-6519, All Lines | PCI-6519, One Line per Port |
| Up to 55 °C | 50 mA | 350 mA | 100 mA | 325 mA |
