Some instruments only support synchronous I/O communication mode. The VISA Test Panel in NI MAX works in this mode (uses the NI-VISA
viWrite and
viRead functions), while the LabVIEW
VISA Write or
VISA Read functions are set to work in an Asynchronous I/O mode by default.
To set the VISA Write and VISA Read functions to operate in synchronous mode, open the contextual menu of the function, navigate to "Synchronous I/O Mode," and then select "Synchronous" from the shortcut menu to read or write data synchronously, as shown in the image below. This procedure must be repeated for each VISA function used to communicate with the instrument.
