Measure Digital Input and Output Simultaneously Using Same Port in PCI-6528
Updated Sep 29, 2024
  • PCI-6528
Is it possible to measure digital input and digital output simultaneously using same port in PCI-6528?
PCI-6528 has 6 ports which contain port 0~2: digital input and port 3~5: digital output. They can measure digital input and output simultaneously if only they connect the input/output according to the respective ports.
