This crash can be caused by a number of factors. The steps below help to troubleshoot the issue.
Note: If the DLL is developed by a 3rd party, NI are not responsible for how it interacts with TestStand. Contact the DLL's developer to understand how the DLL works.
- Remove the DLL-calling VI from the PPL and try loading it into TestStand using the VI's path rather than the PPL's path.
- Ensure that the DLL has been configured to use the C or stdcall calling conventions.
- Other calling conventions are unsupported and will result in a crash.
- Check whether the DLL tries to create any files or folders.
- Some DLLs will create log files for debugging purposes. If the DLL tries to generate this file in the TestStand application directory, a crash may occur due to insufficient permissions.
- Generate a WinDbg Dump file for TestStand.
