Dragging and Dropping NI-DAQ™mx Remote Tasks From NI MAX Into LabVIEW
Updated May 20, 2024
  • NI-DAQ™mx
  • I tried to drag and drop NI-DAQ™mx local task into my block diagram of LabVIEW and it transformed into a constant as expected, however when I try the same process with a remote task it does not work, it only converts into a tag. Why is this happening?
Remote data acquisition is not supported by the NI-DAQmx driver, which means that the fact of a remote task not converting into a constant when dragged from NI MAX and dropped into a block diagram of LabVIEW is not an error but an expected behavior, since this feature is only available for local systems.
NI recommends using network communication for remote data acquisition, for more details check the Using the LabVIEW Network-Published Shared Variable and OPC With NI-DAQ™mx guide.
