Can I assign multiple licenses to one client using the Volume License Manager?
Updated Oct 27, 2026
  • Volume License Manager
Can I assign multiple licenses to a single client using Volume License Manager? Additionally, is it possible to assign different license types, such as a user-based license and a computer-based license, to the same client and use both licenses simultaneously?
Yes. You can assign multiple licenses, including different license types, to a single client as long as the total number of assigned licenses does not exceed the available license seats.
A client can also check out multiple licenses simultaneously.
Licenses can be assigned using the standard methods in Volume License Manager, either by approving a license request from the client or by manually registering the client information and assigning the required licenses. Once the licenses have been assigned, the client can use them normally.
Volume License Manager example
