Having 200ms Delay in TCP/IP Communication
Updated Nov 4, 2020
  • sbRIO-9205
  • cRIO-9045
I'm communicating with a device using TCP/IP communication, and I often see a 200ms delay in the data, what could be causing this delay?
This delay can be caused due to an inherent 200ms delay in TCP/IP communication when the Nagle algorithm is being used.
LabVIEW uses the Nagle algorithm by default, so in order to disable it, you can follow the instructions provided here.
