I Want to Simulate the PXIe-4300 in Its Full Range (+-300V) but Can Not Go Beyond +-10 V
Updated Oct 21, 2020
  • PXIe-4300
  • TB-4300B
When trying to set the voltage range in my simulated PXIe-4300 testpanel in NI MAX to +- 300 V I get the error -200077 when starting the simulation.
For the card to work in its maximum range, the adapter block TB-4300b is necessary, it can also be simulated. Simply rightclick the simulated card in NI-MAX, choose configure and then add the TB-4300b. After that the test panel will work as expected.
