define the following formatting for the labels of the x-axes in the plot dialog :
@@CFV Mod 720@@ (or 360). Then you want to change the x-axes scaling from automatic to
Ticks manual. Set the tick value to
360 (180). It should now present the circular data continously with the correct angle as x-Axis.
