Error 14217 When Launching VIAnalyzer From LabVIEW CLI Operation
Updated Oct 20, 2020
When lauching VI Analyzer through the command line, using the LabVIEW CLI operation, I face error 14217 :
This error tells that the VI Analyzer API cannot work on project-based VI Analyzer Config Files (viancfg).
You must create a config file based on a directory if you want to use the CLI version of VI Analyzer.
To perform that :
  1. Select the first option "Start a new VI Analyzer task"
  2. Click Next
  3. Click "Add Top-Level Item"
  4. Go to your directory and click "Current Folder"
