Time stamp contorl/indicator in Web VI is fixed as "MM/dd/yyyy hh:mm:ss.fff tt" format. This document describes how to change time stamp format as you like.
For example, if you use default format, format-string='MM/dd/yyyy hh:mm:ss.fff tt', you can see something like this.
If you change format string to format-string='yyyy/MM/dd hh:mm:ss.fff tt', results change.
A valid service agreement may be required, and support options vary by country.
