Changing FTP Server Password for Real-Time Controllers
Updated Nov 12, 2020
  • LabVIEW Real-Time Module
This tutorial outlines how to password protect a Real-Time (RT) controller from unwanted FTP Clients by changing the FTP Server Password on the Real-Time Operating System.
Navigating to your RT Controller in MAX
  1. Open MAX by navigating to Start»All Programs»National Instruments»Measurement & Automation.
  2. Left-click the symbol next to Remote Systems
  3. Right-click the RT target, and select Set Permissions.
Depending on whether or not you have "NI Web-based Configuration and Monitoring" installed, you'll take different steps to set the password.
"NI Web-based Configuration and Monitoring" NOT installed
  • Enter your new password twice in the dialog box, and click OK
  • Log into the web server by clicking Login at the top of the navigation bar.  The default username and password is admin with a blank password
  • Click on Change Password
  • Type in your desired password twice in the new dialog box, and click OK
  • Click on the Save button to save your changes
  • Click OK on the dialog box requesting you to log out of the system
Configuring your Real-Time FTP Server
The FTP server's password is the same as the new password specified in the previous step. The Real-Time FTP server ignores the username. Therefore, any username can be entered when logging into the FTP server. If you wish to connect through Internet Explorer to a password protected FTP server, you must specify a username and password in the URL. A properly formatted URL is:
ftp://username:password@ip_address
username:This is any username. Internet Explorer requires a username, but the Real-Time controller will ignore it.
password: This is the password set when locking your controller.
ip_address: This is the IP address or DNS name of your controller.
For example:
The URL of ftp://a:locked@10.0.35.196 would open an FTP session to the controller of IP address 10.0.35.196 with a password of locked.
Note: If you specify only the IP address of a password protected controller in the URL (and don't specify a username and password), you will be prompted for a username and password in a popup dialog box.  A screenshot of a prompt that you will see using Windows Explorer is below
Note: All Real-Time Linux targets will not have the FTP Server installed by default.  You will need to install the FTP Server through the Software tab in Measurement & Automation Explorer. Real-Time Linux targets  feature a WebDAV Server providing secure file system access over HTTP and HTTPS with NIAuth digest authentication.  WebDAV is the recommended method for file transfers.
