Can I call LabVIEW Run-Time Engine 64-bit in TestStand 32-bit?
Updated Oct 15, 2020
  • TestStand
  • LabVIEW Runtime
I have a LabVIEW VI written with LabVIEW 64-bit and I want to run this in TestStand 32-bit using the Runtime adapter. Is this possible?
It is not possible to run a 64-bit LabVIEW VI in the LabVIEW Runtime Engine in TestStand 32-bit.
However, it is possible to run this with the LabVIEW Development System by configuring the adapter under the Adapter Configuration.
This works in the Development Environment because TestStand can call the LabVIEW.exe as a separate process.. However, the LabVIEW Run-Time Engine is a DLL and cannot be called separately; this must be in-process in the TestStand thread.
