Building a Microsoft Word Template and Adding Content to Bookmarks Using LabVIEW Report Generation Toolkit
Updated Feb 13, 2026
Other
Microsoft Word
LabVIEW Report Generation Toolkit gives you the ability to create a Microsoft Word Document based on a Microsoft Word Document Template. This tutorial will cover the process of first building a Word Document and adding bookmarks then saving this as a Word Document Template file. Next, LabVIEW Report Generation Toolkit will be used to create a Word Document based on this template and add content to the bookmarked locations.
Adding Bookmarks to a Microsoft Word Document
In Microsoft Word, a bookmark can be used to identify a location or group of text within a document that you can reference for future use. Adding a bookmark to a document effectively "ear-marks" the location or text selected and allows you to name this label or selection. Before creating a bookmark, it is wise to make bookmarks visible in Word's preferences. This can be done by following the steps below:
  1. Click File >> Options >> Advanced.
  2. Scroll to the Show document content section.
  3. Place a checkmark in the Show bookmarks option.
Figure 1: Word Advanced Options to Show Bookmarks
With this option selected, bookmarks will be shown enclosed by gray brackets. To add a bookmark to a word document follow these steps.
  1. Select the text you want to bookmark, or click the location you want to bookmark.
  2. Under the Insert tab click Bookmark.
  3. In the Bookmark Window that appears, name the bookmark you have just created and click Add.
Note: The bookmark name can contain numbers but must start with a letter. Also, spaces can not be included in the bookmark name, however underscores can be used to separate words.
If you have enabled bookmarks to be shown as described above, your bookmark will appear as shown below.
Figure 2: Examples of Bookmarked Text and Location
With your document bookmarked, you can now save this as a Microsoft Word Document Template. You can save to a Microsoft Word Document Template by clicking File >> Save As and selecting the Word Template (.*dotx) file type from the drop-down menu. This will allow you to create additional Microsoft Word Documents based off of the same design format.
Figure 3: Save As Word Template Option
Adding to Word Document Created from a Template
If you have a Word Document Template file, LabVIEW Report Generation Toolkit allows you to create a Word Document based on this template. The Create Report VI can be used to create a new word document with a format based on the template's design.
Once the template is opened, content can be added to the bookmarked locations using the following VIs:
In the case of the Append List to Report VI, the bookmark name can be directly entered as an input as seen below.
Figure 4: Append List to Report VI Pin Characteristics
With all other Append to Report VIs, the bookmark name must be defined in the MS Office Parameters cluster. This cluster is made up of 4 values: Row, Column, Name, and Bookmark. The first three values are used for Excel documents and can be left blank.
Figure 5: Append Report Text Pin Characteristics
Please refers to the LabVIEW shipping example Word Report - Generate from Template.vi for more details.
