LabWindows™/CVI™ Shows ActiveX Control is not Licensed for this Operation
Updated Jun 13, 2025
  • LabWindows/CVI
I have encountered the following errors when I am trying to call Microsoft Rich Textbox Control from RICHTXT32.ocx by using LabWindows™/CVI™ 2019. How should I resolve this issue?
NON-FATAL RUN-TIME ERROR
"MainForm.c".line 141, col 21, thread id 6384
Function LoadPanel: (return value == -168 [0xffffff58]).
ActiveX control is not licensed for this operation
LabWindows/CVI Message
ActiveX control is not licensed for this operation.
This issue can be resolved by:
  • Ensure the version of LabWindows™/CVI™ you are using is compatible with your computer's Operating System.
  • Ensure LabWindows™/CVI™ has been activated successfully.
  • Ensure the ActiveX control has been registered with the operating system.
  • Ensure Visual Studio has been installed on the development computer.
Note that ActiveX controls can have both Design-Time and Runtime-Time licensing. Apparently, the licensing associated with this control is checking whether Microsoft IDEs such as Visual Studio is installed. If not, when CVI ADE tries to create the ActiveX object, a CLASS_E_NOTLICENSED error is returned, which then triggers the error popup saying "ActiveX control is not licensed for this operation".
