Using Format Specifiers in the Error Code Editor in LabVIEW
Updated Oct 30, 2020
I want to use format specifiers in the Error Code Editor in LabVIEW so that I can display different variables in my errors just as I can in the Error Ring editor itself. Is that possible?
Although creating errors in the Error Code Editor allows you create multiple error codes faster and distribute them to another system easier, it does not allow the functionality of using format specifiers in them. That functionality is specific to the Error Ring editor.
