Common Mode Voltage in the NI 9266
Updated Apr 28, 2025
  • NI-9266
What is the common mode voltage in the connection diagram of the NI 9266 module?
The Common Mode Voltage element in the connection diagram indicates that there might be a common-mode voltage or voltage difference between the NI 9266 ground and the chassis or earth ground.
When using the NI 9266, make sure you are using an external power supply within specifications  and that the the AO and COM terminals are connected to the load.
