I Have the Error 80501044 Using the Denso Robot Interface Software
Updated Oct 13, 2021
  • Micropross Accessories
Other
HW : Denso VP 5 axis robot with RC8 controller and NI robot head controller
SW: Denso Robot Interface (Version 1.3.2 and later)
When I start the Denso Robot Interface application, the error code 0x8F501044 is returned.
The error displayed on the mini pendant is 80501044 :
Please follow the steps listed below:
- Turn the key on the mini-pendant to select "Manual" mode
- on the NI robot controller front panel, switch the Auto/Manual button to "Manual" position
- Clear the error on the mini-pendant by pressing the "Ok" button
- Press "HALT COM" button
- Select "Permit" and make sure you have "Read/Write"  permission
If the below message appears on the mini-pendant screen when you press the "HALT COM" button
follow the step below:
1) Open Wincaps software
2) Select the Programmer mode in the User level tab when the software starts
Then follow the first described procedure and make sure you have read/write permission.
Once it is done, select the Operator mode in Wincaps and close the application.
On the NI robot controller front panel, switch the Auto/Manual button to "Auto" position
Turn the key on the mini-pendant to select "Automatic" mode
Launch Denso Robot Interface software.
The error code 80501044 and the error code 8F501044 have the same meaning.
Those errors mean that the controller does not have permission to read data.
If the issue persists, please contact NI technical support team on NI.com when opening a Service Request case using the NI Service Request Manager (SRM).
To open a service request on NI.com please follow the steps described at this link .
