Removing the SLSC-12202 from the Chassis
Updated Oct 1, 2020
  • SLSC-12202
The SLSC-12202 does not have an ejector handle like other SLSC modules and I am having difficulty removing it from my SLSC chassis. How do I remove this module?
NI's recommendation for removing the SLSC-12202 from the chassis is to carefully pull on the faceplate, if the adjacent slots are empty.
If these slots aren't empty, or you experience difficulty when attempting to remove it with your hands, use of a poly/nylon pry-bar, such as those found in an Ironton 11-Pc Fastener Removal Tool Kit, on the screws.
