When two or more identical NI Switch Executive configurations are required, you can create a single configuration and then duplicate it for one or more additional switches. The following twelve-step procedure requires Microsoft Excel and uses two simulated PXI-2527 switches for illustration.
Right-click on the configured NI Switch Executive Virtual Device you wish to duplicate (i.e. SwitchConfiguration2527A). Select Export to create an .xml file.
Right-click on NI Switch Executive Virtual Devices and select to Create New NI Switch Executive Virtual Device...
C:\Program Files\National Instruments\Switch Executive\Examples\Excel.
